Sonarr version (exact version): 3.0.6.1196
OS: Windows 10
Debug logs: https://pastebin.com/3jh64eT7
I can’t seem to download the Superman & Lois show reliably. I only recently added the HEVC and x265 filters to my download criteria, but it’s been a problem before that. I just enabled debug logging and most of the entries are rejecting the x265, but there are multiple results for each episode on my indexing site (NZB Finder). However the show comes up as “Superman.and.Lois” on the indexer, so I’m wondering if that’s why Sonaar’s not grabbing them. I submitted an entry to the google docs spreadsheet (row 3069, posted June 3rd; TVDB ID 375655) and they said to submit a post on the forum.
From what I can see by searching “S01E08”, the only one it finds contains x265, but again my indexer has multiple posts of all qualities that don’t contain X265 or HEVC in their description.
Can someone tell me what’s going on? For the most part Sonaar works very well but it’s been super flaky with this show.
The ones that it does see, are ones that I’ve downloaded manually and copied to the folder.
Thanks!!
