Sonarr version (exact version) : 2.0.0.5338 Mono version (if Sonarr is not running on Windows) : 5.20.1.34 OS : Linux/Unraid Server Debug logs : Description of issue :
After using Sonaar for the last 2 weeks, downloading episodes fine, this morning I see it downloaded the same episode twice overnight.
I have a cutom profile setup that will download either 4k or 1080P, for 1080P I have it at WebDL-1080P and HDTV-1080P. Quality is set at max 2.8GB. I have the cutoff at WebDL-1080P 2.8GB in size.
In Sonarr, the history shows both downloaded successfully.
When I look at deluge I see both downloaded successfully.
The.Blacklist.S07E02.Louis.T.Steinhil.The.Conclusion.2.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb
then 15min later
The.Blacklist.S07E02.Louis.T.Steinhil.The.Conclusion.2.REPACK.1080p.AMZN.WEB-DL.DDP5.1.H.264-NTb
Both files are the same size in deluge 3GB
I must haved something set incorrectly but not sure what. Any assistance is appreciated.
" Only root can give files away, if you’re trying to change the user a file belongs to it will fail."
Honestly, I’m not sure what that means. In Permissions I do have the following
File chmod mask 0777
Folder chmod mask 0777
chown User nobody
chown Group users
Giving a way a file is changing the owner to a different owner, if the file is owned by somebody you can’t change the owner to nobody if Sonarr is running as somebody. somebody also can’t steal the file from nobody.
Are you running Sonarr as nobody?
Who owns the file on disk?
