Bit of an unusual one here, probably, but hoping that somebody might have a bright idea.
I have Sonarr running via docker on my Syno NAS. However, because the VPN setup for Synology applies to the whole device (or nothing) - there’s no service-based routing - I’ve been searching around and the generally accepted solution appears to be to run a VirtualDSM instance with a VPN configured, and run Sonarr/Radarr/DownloadStation on that. That way, the downloads (and Sonarr/Radarr) go through the VPN, but everything else running on the ‘real’ NAS goes straight out to the WAN. This means I can download from iPlayer without the VPN interfering, for example.
I’ve got it all set up - DS is working, Sonarr and Docker running on the VDSM, so it’s 99% there. I can contact DS via its API from a third-party process on the VDSM. However, when I try and connect Sonarr to the DS as a download client, it fails - and I’m not sure why. Same for Radarr. There’s probably some weird networking thing with Docker/VDSM/Sonarr etc, but not really sure how to figure it out or debug.
Has anyone done a setup like this? It’s mentioned in a few places on Plex/Sonarr/Synology forums, so probably reasonably common. If so, did you have to do anything magic to make this work?
Any suggestions gratefully accepted.
