SOLVED Raspberry PI Zero + deluge + Sonarr
This is a general question, I have build my environment on a Raspberry PI Zero, and at the moment I am getting some interesting results…
The Sonarr and deluge are working fine and downloading torrents, but when I try and access the deluge or Sonarr via the WebIU I am getting a black website informing me that it can’t display results.
this is due to the hardware of the Raspberry PI zero not up to the task ? and that I need to be looking at the raspberry PI 2 or 3 ?
It’s possible, the raspberry pi zero doesn’t have much RAM or processing power.
I have order a Raspberry PI 3, as it was only £2 more then a the PI2. yes it is over kill with the bluetooch and wireless connections, but hopefully with the more powerfully CPU and more RAM that the remote functions will work
my discover for this are:
the wireless power management was turn on, and after awhile this putting the wireless into sleep mode.
the other problem I had was that the PI Zero didn’t have another onboard power to ran all the services
