[solved]Failed to add Indexer through Jackett
Sonarr version (exact version): 2.0.0.5085
Mono version (if Sonarr is not running on Windows):5.8.0.108
OS: Linux
Debug logs: https://pastebin.com/64TE1k31
Description of issue: First off I don’t know my OS distro since I’m renting a shared seedbox (seedhost.eu). I already tried their support and they directed me to Sonarr devs.
I’m trying to add Torznab indexers through Jackett (ThePirateBay) and it fails every time. I’ve attached the Debug logs and any guidance would be appreciated. I’ve already tried reinstalling both Sonarr and Jackett.
I’ve managed to add 1337x, no idea how though. It kept throwing the same error as the one attached, but when I turned on Debug logs and went to capture the failure it just went through, no issues. TPB still fails though. Let me know if I can elaborate on something to make my situation clearer.
Thanks!
It looks like you’re passing in the wrong URL to Sonarr, you want to copy the Torznab URL from the Jackett UI.
I’m doing just that. This is it https://dark.seedhost.eu/wolframalpha/jackett/api/v2.0/indexers/thepiratebay/results/torznab/
I got this by clicking on the Copy Torznab feed button.
Same error https://pastebin.com/Q4LvQjyC
What is the API Path field set to? (It’s an advanced setting)
Looks like it may be set to 80 instead of the default /api.
That solved it. The fields were being auto changed from the defaults after a second of opening the custom tab on TorzNab for some reason. Thank you so much!
