Sonarr version (exact version): 2.0.0.4472
Mono version (if Sonarr is not running on Windows): 4.6.2 (Stable 4.6.2.16/ac9e222 Tue Jan 3 12:12:14 UTC 2017)
OS: debian/jessie/raspberryPi
((Debug logs)): [deleted]
Description of issue: I did some searching , but couldn’t find it answered - Does Sonarr just not work with the thin version of Deluge? i.e. only works with the webUI version?
I’m Using a raspberry pi with sonarr and deluge. Everything played nice when I was using the webUI for deluge. I recently switched to the thin-clinet/console/GTK version (removing the webUI component) of deluge as it’s less stress on the pi. But now, sonarr can’t connect.
I am connecting to the daemon port (58846) that deluge uses (which works fine for connecting with the deluge app, for a full front end) - tried using ‘localhost’ and the IP in sonarr. Tried different passwords and no password for deluge. Not sure what else to try for this ReadDone2 error. Tied restarts etc. Not keen on a fresh install as have had touble in the past (though I haven’t done it in some time) migrating my significant sonarr DB to a fresh install. Is there a guide for loading a backup (from raspi to raspi?) by chance?
Yes, that’s correct at this time.
Thanks @markus101. Bummer though
