Sonarr version (exact version): Sonarr Ver. 2.0.0.5252
Mono version (if Sonarr is not running on Windows): Mono JIT compiler version 5.12.0
OS: Ubuntu Server
Description of issue: Can’t write to samba drive?
I’ve run Sonarr successfully on my Synology for some time, but recently moved Sonarr to a new Ubuntu Server while leaving my TV shows on the Synology NAS.
I’ve successfully mounted a drive so Sonarr is able to catalogue the shows on the NAS but I’m having a problem moving the shows to the NAS once they’re downloaded on the Ubuntu Server computer. As a test, I set the destination folder to be the Ubuntu machine and it worked fine, so I’m fairly sure it’s a permissions issue moving to the NAS. Here’s the log.
Couldn't import episode /data/incomplete/Andi.Mack.S01E01.XviD-AFG/Andi.Mack.S01E01.XviD-AFG.avi: Access to the path "/data/incomplete/Andi.Mack.S01E01.XviD-AFG/Andi.Mack.S01E01.XviD-AFG.avi" or "/synology/TV Shows/Andi Mack/Season 1/Andi.Mack.S01E01.XviD-AFG.avi.partial~" is denied.
System.UnauthorizedAccessException: Access to the path "/data/incomplete/Andi.Mack.S01E01.XviD-AFG/Andi.Mack.S01E01.XviD-AFG.avi" or "/synology/TV Shows/Andi Mack/Season 1/Andi.Mack.S01E01.XviD-AFG.avi.partial~" is denied.
at System.IO.File.Copy (System.String sourceFileName, System.String destFileName, System.Boolean overwrite) [0x00193] in /build/mono/src/mono/mcs/class/corlib/System.IO/File.cs:111
at NzbDrone.Common.Disk.DiskProviderBase.CopyFileInternal (System.String source, System.String destination, System.Boolean overwrite) [0x00000] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskProviderBase.cs:208
at NzbDrone.Mono.Disk.DiskProvider.CopyFileInternal (System.String source, System.String destination, System.Boolean overwrite) [0x00076] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Mono\Disk\DiskProvider.cs:129
at NzbDrone.Common.Disk.DiskProviderBase.CopyFile (System.String source, System.String destination, System.Boolean overwrite) [0x000bc] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskProviderBase.cs:203
at NzbDrone.Common.Disk.DiskTransferService.TryCopyFileTransactional (System.String sourcePath, System.String targetPath, System.Int64 originalSize) [0x00108] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskTransferService.cs:462
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, NzbDrone.Common.Disk.TransferMode mode, System.Boolean overwrite, NzbDrone.Common.Disk.DiskTransferVerificationMode verificationMode) [0x0034a] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskTransferService.cs:289
at NzbDrone.Common.Disk.DiskTransferService.TransferFile (System.String sourcePath, System.String targetPath, NzbDrone.Common.Disk.TransferMode mode, System.Boolean overwrite, System.Boolean verified) [0x0000e] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Common\Disk\DiskTransferService.cs:196
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.TransferFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Tv.Series series, System.Collections.Generic.List`1[T] episodes, System.String destinationFilePath, NzbDrone.Common.Disk.TransferMode mode) [0x0012c] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:119
at NzbDrone.Core.MediaFiles.EpisodeFileMovingService.CopyEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode) [0x0006b] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeFileMovingService.cs:94
at NzbDrone.Core.MediaFiles.UpgradeMediaFileService.UpgradeEpisodeFile (NzbDrone.Core.MediaFiles.EpisodeFile episodeFile, NzbDrone.Core.Parser.Model.LocalEpisode localEpisode, System.Boolean copyOnly) [0x00167] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\UpgradeMediaFileService.cs:72
at NzbDrone.Core.MediaFiles.EpisodeImport.ImportApprovedEpisodes.Import (System.Collections.Generic.List`1[T] decisions, System.Boolean newDownload, NzbDrone.Core.Download.DownloadClientItem downloadClientItem, NzbDrone.Core.MediaFiles.EpisodeImport.ImportMode importMode) [0x00272] in C:\BuildAgent\work\5d7581516c0ee5b3\src\NzbDrone.Core\MediaFiles\EpisodeImport\ImportApprovedEpisodes.cs:107
I’m fairly new to Ubuntu so ciould someone suggest some things for me to take a look at please?
