Sonarr version - 3.0.3.809
Windows 10:
My current set up is Sonarr/Radarr running through my main PC (Localhost) and uTorrent running through a Virtual Machine running Windows 10. I have managed to get uTorrent to store the downloads on my main PC but I can’t seem to get it to move from the directory it saves in to my ‘Movies’ and ‘TV Series’ folders
For example when a torrent is downloading it gets created in D:\Movies & TV\New Downloads and I want them to be moved to either D:\Movies & TV\Movies (If from Radarr) and T:\TV (If from Sonarr)
I have set up the labels in uTorrent, so the it will go to those directories as it shows in the VM.
In the VM they are E:\Movies and F:\TV
I have also set up remote path mapping in Sonarr/Radarr which looks like:
Host: IP address of the VM, Remote Path: E\New Downloads, Local Path: T:\TV
Would it be Remote path: E:\New Downloads, Local Path: D:\Movies & TV\New Downloads\
Or is that also incorrect? And do I need the uTorrent labels to be pointing to the Movie/TV Series folder, or would Sonarr do that once it’s in the ‘New Downloads’ folder?
EDIT
Changed the remote path to E:\New Downloads and the Local path to D:\Movies & TV\New Downloads\ and now once downloaded they move to the correct folder and are then scanned into Plex.
