Sonarr version (exact version): 3.0.7.1479
Mono version (if Sonarr is not running on Windows): 6.12.0.122
OS: Debian
Debug logs: https://pastebin.com/f3ixQc7q
For shows that are releasing currently, individual episodes are downloaded and thats fine. However, when a season is done, my tracker currently deletes all the individual episodes and packs them into a season pack. I would like to easily be able to use the new torrent for seeding. The problem is the new torrent usually comes with a top-level folder, meaning I would have to individually create folders for each show that I would upload.
I am using qbit, so a solution to this is to enable the option to disregard the first directory of the torrent, which works okay. The problem now is, that if Sonarr cannot guess a torrents show from its name, I need to manually import it. This is no big deal, but since there is now top-level folder, Sonarr scans through all files in the folder, most of which have already been imported. This is somewhat slow and confusing, so I was wondering if there were any clever heads among those reading this, that might have a solution to this where:
- Individual episodes can be downloaded
- When season packs are released, I can just recheck them all to the same base location
- Doing a manual import on a torrent in the folder only considers the files in the actual torrent.
Thanks for your time
