What am I supposed to put into the Icon field when setting up slack notifications? I don’t want an emoji and it doesn’t allow it to be empty. I tried an url, but then it just displays default bot logo. In slack settings I set an icon successfully, but the setting in sonarr seems to override it.
It’s an emoji, when I was testing it I published a custom emoji and used that. I’ll take a look and see if it can be excluded which should use whatever was set in the settings.
I actually just ran into this today as well. I think it should be an optional field in Sonarr itself, since by default it can use whatever is setup in the webhook on Slack.
