Simple Synoindex Server - Syno dlna Index when in Docker
OS: Docker for Synology
Hello, I’m running Sonarr in Docker on my Synology.
I’m trying to get synoindex working for my dlna index to be updated.
I’ve found that : GitHub - racklin/simple-synoindex-server: Simple synoindex server for Synology NAS This should do the trick but I’m noob enough to need help setting this up.
While I’ve read it multiples times and I’ve looked for info on the web, I can’t get it to work.
I hope someone could help me with this.
As I understand :
1/ I extracted the package in a directory of my choice on my syno.
2/ I added a mapping path to my docker setting
docker/simple-synoindex-server to /usr/syno/bin
3/ I update the .ini file with my server setting
192.168.0.21 (172.17.0.0 didn’t work for me when trying to test the syno index sonarr connector)
port : 32699
and volume mapping settings
/tv=/volume1/video/Series
/movies=/volume1/video/Films
4/ I set a task to run the binaries on boot and started it manually
The scipt set is :
/volume1/docker/simple-synoindex-server/synoindex-server &
When I look at the execution result there’s “no datas” in “script” and “no datas” in “standard output/error”
5/ Then I went to sonarr to add the connector that worked properly when tested
But still, my DLNA Index is not updated when a downloaded files is moved to my tv folders.
Any clue ?
Well, I finally got it working with 172.17.0.1 and this script for the task scheduler
sleep(60) && /volume1/homes/admin/simple-synoindex-server/synoindex-server &
but there is a small limitation due to this bug :
New file is indexed only if a directory already exists.
It is well documented here : Possible Synology indexer notification bug - #9 by Igor
Do you know if this issue will be adressed in v3 ?
