The last few releases of the develop branch are having a problem with not updating the UI when searching, etc. Nothing was really showing up in the logs, even with it turned all the way up to “trace”. I turned web debugging on in Firefox and found that the call to /signar/negotiate was returning a 500 error:
It’s fairly easy to duplicate with cUrl:
$ curl -v "http://192.168.242.3:8989/signalr/negotiate?_=1432861240909"
* Trying 192.168.242.3...
* Connected to 192.168.242.3 (192.168.242.3) port 8989 (#0)
> GET /signalr/negotiate?_=1432861240909 HTTP/1.1
> User-Agent: curl/7.40.0
> Host: 192.168.242.3:8989
> Accept: */*
< HTTP/1.1 500 Internal Server Error
< Server: Mono-HTTPAPI/1.0
< Date: Fri, 29 May 2015 01:12:59 GMT
< Content-Length: 0
< Connection: close
* Closing connection 0
I’m not sure if this is a bug in Sonarr or something I’ve done - I’ve been changing around how I run Sonarr so I could have messed something up but everything else seems fine.
I’m running version 2.0.0.3189 currently but I’ve been seeing this problem for a little while.
