OS: windows pc
Description of issue: in order to get to the 3 bars on top of the side panel to close it I need to zoom in at least to 125% way to big to really see much on the screen. I can close it at 125% but if I lower the zoom the panel comes back again. 2 monitor system it does the same on both 55" and 30" tried on chrome and Edge same problem. thanks for any help
AFAIK the 3 bars only appear when it is displaying in mobile view / using mobile styling.
Desktop mode does not have the ability to hide the sidebar. Once you zoom past a certain point, the styling switches automatically and the 3 bars appear.
ok thanks for the reply
