Hi
new Sonarr user here. Desperately trying to get MP4_automator installed on Catalina so that I can have a library of MP4s not MKVs.
I’ve spent hours on the google machine and reading these forums and there’s simply no beginners level material out there. Can anyone tell me (using little words, like you were talking to a child) how to install automator?
For example. The instructions say
- Rename autoProcess.ini.sample to autoProcess.ini inside your
config
directory (or attempt to run the script which will generate a new config file if absent)
Except the config file is empty. Running the script throws errors and does not produce an ini file
I’m clearly missing the step where you register all the python with the system. Hold my hand?
thanks
