Sonarr Version: 2.0.0.4472
Mono Version: mono --version
Mono JIT compiler version 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4)
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
Operating System: Ubuntu server 16.04 (no antivirus)
Description of issue: Whenever I try to access the Settings tab it never loads (I get the grey dots moving back and forth). It is a new install, adding/editing seasons works fine; however I can’t add an indexer or a client!
Sonarr is running remotely on my fileserver and I’m accessing from my desktop (also linux, tried firefox and chromium).
I’ve read a few threads relating to this issue. I can access the login screen. When I try to make an API call directly (e.g. http://files:8989/api/config/indexer) I get “error”: “Unauthorized”.
Any guidance you can offer is appreciated!
Log snippet:
17-1-29 10:48:56.1|Info|Bootstrap|Starting Sonarr - /opt/NzbDrone/NzbDrone.exe - Version 2.0.0.4472
17-1-29 10:48:56.4|Info|MigrationLogger|*** Migrating data source=/var/lib/nzbdrone/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-1-29 10:48:56.5|Info|MigrationLogger|*** Migrating data source=/var/lib/nzbdrone/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
17-1-29 10:48:56.6|Info|Router|Application mode: Interactive
17-1-29 10:48:56.6|Info|OwinHostController|Listening on the following URLs:
17-1-29 10:48:56.6|Info|OwinHostController| http://*:8989/
17-1-29 10:48:56.6|Info|NancyBootstrapper|Starting NzbDrone API
17-1-29 10:49:02.9|Fatal|NzbDroneErrorPipeline|Request Failed
[v2.0.0.4472] System.InvalidOperationException: Sequence contains more than one element
at System.Linq.Enumerable.SingleOrDefault[TSource] (IEnumerable`1 source) <0x40dc3ed0 + 0x001db> in <filename unknown>:0
at NzbDrone.Core.Datastore.BasicRepository`1[TModel].SingleOrDefault () [0x00000] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Datastore\BasicRepository.cs:96
at NzbDrone.Core.Organizer.NamingConfigService.GetConfig () [0x00000] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Organizer\NamingConfigService.cs:20
at NzbDrone.Api.Config.NamingConfigModule.GetNamingConfig () [0x00000] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\Config\NamingConfigModule.cs:54
at NzbDrone.Api.REST.RestModule`1[TResource].<set_GetResourceSingle>b__38_0 (System.Object options) [0x00000] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Api\REST\RestModule.cs:141
at (wrapper dynamic-method) System.Object:CallSite.Target (System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,System.Func`2<object, object>,object)
at Nancy.Routing.Route+<>c__DisplayClass4.<Wrap>b__3 (System.Object parameters, CancellationToken context) <0x40f69600 + 0x0014f> in <filename unknown>:0
17-1-29 10:49:26.9|Info|RssSyncService|Starting RSS Sync
17-1-29 10:49:26.9|Warn|FetchAndParseRssService|No available indexers. check your configuration.
17-1-29 10:49:26.9|Info|DownloadDecisionMaker|No results found
17-1-29 10:49:26.9|Info|RssSyncService|RSS Sync Completed. Reports found: 0, Reports grabbed: 0
