Hey all, Just struggling to find a guide or to figure out for myself how to set up Sonarr to move completed downloads for a TV show into the respective folders for PLEX. ie. place the episodes into the appropriate Season folder. I’m not using docker, that seemed worth mentioning as most guides seem to refer to that.
I’m using Deluge to download. At the moment, downloads remain in Deluge’s ‘completed’ folder. I’ve set Deluge up to remove the downloads once completed.
Everything else is otherwise working, just not this.
it does this by design… unless you set your root folder in your downloads folder which causes issues and means you’re ignoring a healthcheck about downloading into you root folder
I’m not sure what you mean about setting my root folder in my downloads folder, can you pls expand on that?
Just reading those articles, it sounds like your saying I shouldn’t download into my library, that’s not what I mean and it’s not what I’m trying to do, because Deluge can’t sort downloaded files into their respective TV show and season subdirectories, so that wouldn’t work anyway.
I want Sonarr to move files from my E:\Torrents\Complete folder to my PLEX library in their appropriate locations. Is it capable of that?
