Sonarr version (exact version): 2.0.0.5085 Mono version (if Sonarr is not running on Windows): 5.4.1.6 OS: Docker on Ubuntu Server 17.10 Debug logs: (Make sure debug logging is enabled in settings and post the full log to hastebin/pastebin/dropbox/google drive or something similar, do not post them directly here) Description of issue:
Hey, I’m sorry you’re probably sick of seeing these type of threads. I have an issue, where i can’t map my DDWRT nas to sonarr.
You need to mount the SMB share to your docker container (probably to the host then add a volume to add it to the container). \\dd-wrt\DDWRT\Downloads is a Windows UNC path and won’t work in the docker container.
I got it working, you can lock this thread. Mounting the drive in linux took way more than expected, also had permission issues. Managed to get it working with trial and error
