Any way to stop PROPER/REPACK from being auto downloaded? I just had 2 downloads of the same tv show within the same hour. The original was fine! In fact, I can’t think of a time when I’ve needed a ‘PROPER/REPACKED’ version to be downloaded. If I do then Ill just manually choose and download a new version.
Perhaps a settings switch to disbale this behaviour?
Besides, even if you add the phrase to ignored, you can still trigger the download manually. You’re not “toast”.
Personally, I’d prefer being notified about the PROPER. That would allow me to make a decision before redownloading.
And his next lines was "I just had 2 downloads of the same tv show within the same hour. ", clearly he meant the upgrade to proper for the same quality.
As markus mentioned, there’s an option to disable that, and if it isn’t working as intended then we need log files since there likely is another reason why it happened. Exactly what OP is doing.
I simply remarked that your proposed workaround has unintended side effects that other users need to be aware of. And that other users having the same problem should do the same as OP, and gather log files.
Falling over semantics isn’t going to help anyone.
