Sonarr version 4.0.12.2823
OS ( run in NAS Synology)
Hello evrybody
i have à problem with sonarr , im trying to download a series ( the Night of ) but sonnar dont find it in YGG indexer , i check and this series exist on it
It seen no problem with language or release , i configured only YGG indexer by using cookies with prowlarr , im using qbitorrent
thers is logs
2025-02-10 20:05:23.7|Debug|Api|[GET] /api/v3/command: 200.OK (3 ms)
2025-02-10 20:05:32.2|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2025-02-10 20:05:32.3|Debug|SeriesService|Tags not updated for 'The Night Of'
2025-02-10 20:05:32.3|Debug|Api|[PUT] /api/v3/series/6: 202.Accepted (130 ms)
2025-02-10 20:05:33.7|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2025-02-10 20:05:33.7|Debug|Api|[GET] /api/v3/queue/details?seriesId=6: 200.OK (11 ms)
2025-02-10 20:05:33.7|Debug|Api|[GET] /api/v3/episode?seriesId=6: 200.OK (14 ms)
2025-02-10 20:05:33.7|Debug|Api|[GET] /api/v3/episodeFile?seriesId=6: 200.OK (19 ms)
2025-02-10 20:05:35.3|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2025-02-10 20:05:35.4|Debug|Api|[POST] /api/v3/command: 201.Created (58 ms)
2025-02-10 20:05:35.4|Info|ReleaseSearchService|Searching indexers for [The Night Of : S01]. 1 active indexers
2025-02-10 20:05:35.4|Debug|Torznab|Downloading Feed http://localhost:9696/8/api?t=tvsearch&cat=5000,5050&extended=1&apikey=(removed)&offset=0&limit=100&q=The%20Night%20Of&season=1
2025-02-10 20:05:38.7|Debug|Torznab|Downloading Feed http://localhost:9696/8/api?t=tvsearch&cat=5000,5050&extended=1&apikey=(removed)&offset=0&limit=100&q=Night%20Of&season=1
2025-02-10 20:05:42.8|Debug|ReleaseSearchService|Total of 12 reports were found for [The Night Of : S01] from 1 indexers
2025-02-10 20:05:42.8|Debug|ReleaseSearchService|Setting last search time to: 02/10/2025 19:05:42
2025-02-10 20:05:43.1|Info|DownloadDecisionMaker|Processing 12 releases
2025-02-10 20:05:43.1|Debug|DownloadDecisionMaker|Processing release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.SDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.1|Debug|Parser|Parsing string 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.SDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.1|Debug|Parser|Episode Parsed. Cromanon The Night of the Fire - Season 01
2025-02-10 20:05:43.1|Debug|Parser|Languages parsed: Unknown
2025-02-10 20:05:43.1|Debug|QualityParser|Trying to parse quality for 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.SDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.1|Debug|Parser|Quality parsed: WEBDL-2160p v1
2025-02-10 20:05:43.1|Debug|Parser|Release Group parsed: FW
2025-02-10 20:05:43.1|Debug|ParsingService|No matching series Cromanon The Night of the Fire
2025-02-10 20:05:43.1|Debug|DownloadDecisionMaker|Release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.SDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.1|Debug|DownloadDecisionMaker|Processing release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.HDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.1|Debug|Parser|Parsing string 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.HDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.1|Debug|QualityParser|Trying to parse quality for 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.HDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.2|Debug|Parser|Quality parsed: WEBDL-2160p v1
2025-02-10 20:05:43.2|Debug|Parser|Release Group parsed: FW
2025-02-10 20:05:43.2|Debug|ParsingService|No matching series Cromanon The Night of the Fire
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.HDR.2160p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. Cromanon The Night of the Fire - Season 01
2025-02-10 20:05:43.2|Debug|Parser|Languages parsed: Unknown
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.2|Debug|Parser|Quality parsed: WEBDL-1080p v1
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H265-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H264-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H264-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H264-FW (Cromañon : La Nuit de l'incendie)'
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'Cromanon.The.Night.of.the.Fire.S01.VOSTFR.1080p.WEB.H264-FW (Cromañon : La Nuit de l'incendie)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'In.the.Heat.of.the.Night.S06.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'In.the.Heat.of.the.Night.S06.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. In the Heat of the Night - Season 06
2025-02-10 20:05:43.2|Debug|Parser|Languages parsed: French
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'In.the.Heat.of.the.Night.S06.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|ParsingService|No matching series In the Heat of the Night
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'In.the.Heat.of.the.Night.S06.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'In.the.Heat.of.the.Night.S05.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'In.the.Heat.of.the.Night.S05.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. In the Heat of the Night - Season 05
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'In.the.Heat.of.the.Night.S05.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'In.the.Heat.of.the.Night.S05.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'In.the.Heat.of.the.Night.S03.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'In.the.Heat.of.the.Night.S03.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. In the Heat of the Night - Season 03
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'In.the.Heat.of.the.Night.S03.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'In.the.Heat.of.the.Night.S03.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'In.the.Heat.of.the.Night.S02.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'In.the.Heat.of.the.Night.S02.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. In the Heat of the Night - Season 02
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'In.the.Heat.of.the.Night.S02.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'In.the.Heat.of.the.Night.S02.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'In.the.Heat.of.the.Night.S01.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'In.the.Heat.of.the.Night.S01.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. In the Heat of the Night - Season 01
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'In.the.Heat.of.the.Night.S01.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)'
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'In.the.Heat.of.the.Night.S01.FRENCH.1080p.WEB.H264-FW (Dans la chaleur de la nuit)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Processing release 'Pokemon.Horizons.The.Series.S01E25.Rivals.in.the.Dark.of.Night.DiRFiX.MULTi.1080p.NF.WEB.DDP.AV1-BTT (Pokémon : Les horizons)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.2|Debug|Parser|Parsing string 'Pokemon.Horizons.The.Series.S01E25.Rivals.in.the.Dark.of.Night.DiRFiX.MULTi.1080p.NF.WEB.DDP.AV1-BTT (Pokémon : Les horizons)'
2025-02-10 20:05:43.2|Debug|Parser|Episode Parsed. Pokemon Horizons The Series - S01E25
2025-02-10 20:05:43.2|Debug|QualityParser|Trying to parse quality for 'Pokemon.Horizons.The.Series.S01E25.Rivals.in.the.Dark.of.Night.DiRFiX.MULTi.1080p.NF.WEB.DDP.AV1-BTT (Pokémon : Les horizons)'
2025-02-10 20:05:43.2|Debug|Parser|Release Group parsed: BTT
2025-02-10 20:05:43.2|Debug|SceneMappingService|Found scene mapping for: Pokemon Horizons The Series. TVDB ID for mapping: 76703
2025-02-10 20:05:43.2|Debug|ParsingService|No matching series Pokemon Horizons The Series
2025-02-10 20:05:43.2|Debug|DownloadDecisionMaker|Release 'Pokemon.Horizons.The.Series.S01E25.Rivals.in.the.Dark.of.Night.DiRFiX.MULTi.1080p.NF.WEB.DDP.AV1-BTT (Pokémon : Les horizons)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Pokemon Horizons The Series matches an alias for series with TVDB ID: 76703
2025-02-10 20:05:43.3|Debug|DownloadDecisionMaker|Processing release 'Night.of.The.Long.Knives.2020.DOC.S01.FRENCH.1080p.AMZN.WEB.DDP2.0.H265-TFA (La nuit des longs couteaux)' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.3|Debug|Parser|Parsing string 'Night.of.The.Long.Knives.2020.DOC.S01.FRENCH.1080p.AMZN.WEB.DDP2.0.H265-TFA (La nuit des longs couteaux)'
2025-02-10 20:05:43.3|Debug|Parser|Episode Parsed. Night of The Long Knives 2020 DOC - Season 01
2025-02-10 20:05:43.3|Debug|Parser|Languages parsed: French
2025-02-10 20:05:43.3|Debug|QualityParser|Trying to parse quality for 'Night.of.The.Long.Knives.2020.DOC.S01.FRENCH.1080p.AMZN.WEB.DDP2.0.H265-TFA (La nuit des longs couteaux)'
2025-02-10 20:05:43.3|Debug|Parser|Quality parsed: WEBDL-1080p v1
2025-02-10 20:05:43.3|Debug|Parser|Release Group parsed: TFA
2025-02-10 20:05:43.3|Debug|ParsingService|No matching series Night of The Long Knives 2020 DOC
2025-02-10 20:05:43.3|Debug|DownloadDecisionMaker|Release 'Night.of.The.Long.Knives.2020.DOC.S01.FRENCH.1080p.AMZN.WEB.DDP2.0.H265-TFA (La nuit des longs couteaux)' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.3|Debug|DownloadDecisionMaker|Processing release 'UD2M : Children of the Night 2016 WEB 1080p AAC H264' from 'YGG cookie (Prowlarr)'
2025-02-10 20:05:43.3|Debug|Parser|Parsing string 'UD2M : Children of the Night 2016 WEB 1080p AAC H264'
2025-02-10 20:05:43.3|Debug|Parser|Episode Parsed. UD2M : Children of the Night - S20E16
2025-02-10 20:05:43.3|Debug|Parser|Languages parsed: Unknown
2025-02-10 20:05:43.3|Debug|QualityParser|Trying to parse quality for 'UD2M : Children of the Night 2016 WEB 1080p AAC H264'
2025-02-10 20:05:43.3|Debug|ParsingService|No matching series UD2M : Children of the Night
2025-02-10 20:05:43.3|Debug|DownloadDecisionMaker|Release 'UD2M : Children of the Night 2016 WEB 1080p AAC H264' from 'YGG cookie (Prowlarr)' rejected for the following reasons: [Permanent] Unknown Series
2025-02-10 20:05:43.3|Info|SeasonSearchService|Season search completed. 0 reports downloaded.
2025-02-10 20:05:43.3|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2025-02-10 20:05:43.3|Debug|Api|[GET] /api/v3/command: 200.OK (3 ms)
2025-02-10 20:05:43.3|Debug|Api|[GET] /api/v3/command: 200.OK (4 ms)
2025-02-10 20:05:46.2|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2025-02-10 20:05:46.2|Debug|Api|[GET] /api/v3/health: 200.OK (15 ms)
2025-02-10 20:05:46.3|Debug|Api|[GET] /api/v3/system/status: 200.OK (46 ms)
2025-02-10 20:05:46.3|Debug|Api|[GET] /api/v3/diskspace: 200.OK (114 ms)
2025-02-10 20:05:47.3|Debug|Sonarr.Http.Authentication.ApiKeyAuthenticationHandler|AuthenticationScheme: API was successfully authenticated.
2025-02-10 20:05:47.3|Debug|Api|[GET] /api/v3/log/file: 200.OK (8 ms)
2025-02-10 20:05:49.1|Debug|Sonarr.Http.Authentication.BasicAuthenticationHandler|AuthenticationScheme: Basic was successfully authenticated.
