Version 2.0.0.4472
Mono Version 4.6.2 (Stable 4.6.2.16/ac9e222 Tue Jan 3 11:48:26 UTC 2017)
running with ubuntu 16.04.2
recent logs (I can put any of these up but I don’t think they apply)
XbmcMetadata Unable to process episode image for file: /data/TV/Good Eats/Season 14/Good Eats - Sabnzbd API Grab Limit reached for https://nzbnoob.com/getnzb/cdff95abb7386412d95d88b7c250947b.nzb&i=3201&r=4377f14f5facecc30f87803afff66710 Yesterday
Sabnzbd Downloading nzb for episode ‘Seth.Meyers.2015.07.27.Carli.Lloyd.1080p.HDTV.x264-CROOKS’ failed (http://api.nzbplanet.net/getnzb/002c4ac1fc400e820fde044705a89b1c.nzb&i=6119&r=fd1737138919b6d113be70aa4dd06f8d): The operation has timed out. Yesterday
RefreshSeriesService Couldn’t refresh info for [72231][Real Time with Bill Maher]: The operation has timed out. Yesterday
Owin SignalR exception thrown by Task: System.AggregateException: One or more errors occurred. —> System.ObjectDisposedException: Cannot access a disposed object. Object name: ‘System.Net.ResponseStream’. at System.Net.ResponseStream.Write (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00016] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00006] in <208c8ef8a4ba4b878f0e4420d5960bea>:0 — End of inner exception stack trace — ---> (Inner Exception #0) System.ObjectDisposedException: Cannot access a disposed object. Object name: ‘System.Net.ResponseStream’. at System.Net.ResponseStream.Write (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00016] in <5071a6e4a4564e19a2eda0f53e42f9bd>:0 at Microsoft.Owin.Host.HttpListener.RequestProcessing.ExceptionFilterStream.Write (System.Byte[] buffer, System.Int32 offset, System.Int32 count) [0x00006] in <208c8ef8a4ba4b878f0e4420d5960bea>:0 <— Yesterday
I just noticed that debugging mode should not be turned on all the time and mine has been. (have no idea if this might make a difference)
My problem is that the cover pictures, in the series list, are out of sync with the descriptions. I have searched through all the posts to no avail and the wiki doesn’t seem to mention this. I have tried all the sorts and it makes no difference. Sometimes they are out of sync and, sometimes, the pictures will double up and throw everything off. I can live with this but if there is a way I can fix it …
Thank you…
