"Search for monitored episodes" not working
Mono version (if Sonarr is not running on Windows): 3.2.8
OS: Ubuntu Server 14.04 LTS
((Debug logs)) (posted to hastebin or similar): http://pastebin.com/EpcVnMCc
Description of issue: If I click “Search for monitored episodes in season…” against a season it finds no torrents and subsequently nothing is added to the torrent client. However, if I go to an episode and click “Manual Search” I an see there are valid torrents that meet the requirements available. And if I click Automatic Search next to said episode it finds and adds the correct torrent to my client and processes it correctly.
I have ensured the season is set to monitored and the episodes I want are set to monitored. Weirdly the Search for monitored episodes doesn’t seem to work. I am using TorrentDay as the main indexer that seems to have these episodes via Jackett and search is supported. I’ve had a look through the debug logs but can’t see why it isn’t working.
Any help would be greatly appreciated.
Upgrade mono, you need 3.10 or higher.
16-5-9 11:12:04.9|Debug|DownloadDecisionMaker|Release rejected for the following reasons: [Permanent] Not enough seeders. (0)
Sounds like the results aren’t returning any seeders, at least one seeder is required. Perhaps Jackett isn’t parsing the information or its not available on the indexer.
