This document will expire in 19 hours.
You’ll need to extend or repost this, as others may not see it in that time.
However, the log is essentially just a repeat of:
2024-03-09 14:53:02.9|Debug|Api|[GET] /api/v3/system/status?apikey=(removed) 200.OK (0 ms)
2024-03-09 14:53:06.2|Error|TaskExtensions|Task Error
[v4.0.2.1262] code = Corrupt (11), message = System.Data.SQLite.SQLiteException (0x800007EF): database disk image is malformed
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at Dapper.SqlMapper.ExecuteReaderWithFlagsFallback(IDbCommand cmd, Boolean wasClosed, CommandBehavior behavior) in /_/Dapper/SqlMapper.cs:line 1075
at Dapper.SqlMapper.QueryMultipleImpl(IDbConnection cnn, CommandDefinition& command) in /_/Dapper/SqlMapper.cs:line 1058
at NzbDrone.Core.Datastore.BasicRepository`1.Insert(IDbConnection connection, IDbTransaction transaction, TModel model) in ./Sonarr.Core/Datastore/BasicRepository.cs:line 188
at NzbDrone.Core.Datastore.BasicRepository`1.Insert(TModel model) in ./Sonarr.Core/Datastore/BasicRepository.cs:line 151
at NzbDrone.Core.Messaging.Commands.CommandQueueManager.Push[TCommand](TCommand command, CommandPriority priority, CommandTrigger trigger) in ./Sonarr.Core/Messaging/Commands/CommandQueueManager.cs:line 138
at NzbDrone.Core.Messaging.Commands.CommandQueueManager.Push(String commandName, Nullable`1 lastExecutionTime, Nullable`1 lastStartTime, CommandPriority priority, CommandTrigger trigger) in ./Sonarr.Core/Messaging/Commands/CommandQueueManager.cs:line 142
at NzbDrone.Core.Jobs.Scheduler.ExecuteCommands() in ./Sonarr.Core/Jobs/Scheduler.cs:line 42
at System.Threading.ExecutionContext.RunFromThreadPoolDispatchLoop(Thread threadPoolThread, ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
at System.Threading.Tasks.Task.ExecuteWithThreadLocal(Task& currentTaskSlot, Thread threadPoolThread)
