I saw some other threads with the same issue but it didn’t seem to be fixed.
After a day or so, all the scheduled tasks stop running. If I restart Sonarr, they will immediately start working until they stop again.
I’m using:
Ubuntu 14.04.2 LTS (Server)
Sonarr Version 2.0.0.3645
Mono Version 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1.1)
Image showing tasks not running
I enabled trace logging.
The log files can be found at rontonsoup.com/sonarr
You can either look at the individual files or there is a zip in there containing all of them.
Direct link to zip: http://rontonsoup.com/sonarr/logs.zip
Thank you for any help.
You need to upgrade mono to at least 3.10, but 4.2.1 is preferred.
EDIT:
I had multiple installs for mono in apt-get. I removed a previous one and now sonarr is reporting a mono version of 4.2.1.
Hopefully this fixes my issue.
Thanks!!
Orig post:
If I run mono --version on command line it seems to indicate 4.2.1 is on the server, yet when looking at Sonarr, it still says 3.2.8.
pogostick@pogostick2:~$ mono --version
Mono JIT compiler version 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Nov 12 09:52:44 UTC 2015)
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
LLVM: supported, not enabled.
GC: sgen
Then two different versions are installed, likely the method that you’re using to start Sonarr points to another copy.
Didn’t see your post when I edited mine. Yeah, this was the problem, I cleaned up my installs and now Sonarr is reporting a matching mono version.
Thanks!
Sonarr is using Mono Version 4.2.1, yet the tasks still have the same problem as originally stated.
system
Closed
8
