Scene Mapping V2
Hi,
First off, thanks for all the work that went into V2 of the application.
Now on to my issue, when V2 is searching for Pawn Stars or American Pickers it will perform a lookup to determine what the scene naming of the episode is from the TVDB episode number. In the logs I can see it doing this correctly and it does find the files but it will not download it.
I then do a manual search and I am presented with the same files and the message I get is that the episode number is different which is why it is not downloading it. Obviously we know it is different because it used the scene numbering in order to perform the search.
Is this suppose to happen or have I missed a setting somewhere?
Its a bug. I’ll take a look at it.
EDIT: Found the cause, will get that fixed up and released ASAP.
Mythbusters.S12E10 is behaving very oddly. Looks like a Mapping problem again.
File is called
[#a.b.teevee] Mythbusters.S12E10.Breaking.Bad.Special.720p.WEB-DL.AAC2.0.H.264-XEON - “Mythbusters.S12E10.Breaking.Bad.Special.720p.WEB-DL.AAC2.0.H.264-XEON”
Not really sure how to input it to the form as it is a single episode rather than an entire series that is failing.
Numbering issues need to be fixed on thexem.de.
Pretty sure its not a numbering issue as it appears on thetvdb.com as s12e10
http://thetvdb.com/?tab=episode&seriesid=73388&seasonid=488093&id=4575924&lid=7
nzbdrone is also matching it correctly to Mythbusters S12E10
nzbdrone is also putting an “!” saying unknown series
What indexer are you getting that from? nzbclub? The name is correct for my newznab indexers (I have nzbclub off because it only half works).
If its treating: “[#a.b.teevee] Mythbusters” as the name it would definitely be wrong.
indeed, both being picked up by nzbclub.
I will disable that and wait for a better release. Thanks for sorting Dragons Den btw, thats working correctly now.
this seems to have broken in 2.0.0.256. Manual Searches find nothing. Downloading a season 7 episode of pawn stars results in a “Cannot find episode” error.
ParsingService Unable to find pawnstars - S07E22 HDTV-720p 10:00 AM
ImportDecisionMaker Analysing 1/1 files. 10:00 AM
DiskScanService Scanning ‘H:\downloads\Pawn Stars S07E22 720p HDTV x264-EVOLVE’ for video files
It’s broken because that mapping isn’t there (TheXem doesn’t know anything about S07E22), NzbDrone can only use the information that is available on TheXem, so you (or someone else) will need to add it before it works again.
http://thexem.de/xem/show/731
American pickers appears to be toast as well. I’ll check out the XEM setup.
so XEM has had a show setup for American Pickers but no settings for it. Nor do I think any are really needed.
Is there a way to get NZBdrone to “ignore” the XEM based naming.
I’m looking at it right now, http://thexem.de/xem/show/737 - it looks right to me and is required, based on a couple checks:
Scene has S03E02, but TVDB doesn’t
Scene has S05 and TVDB doesn’t
Did you compare it to TVRage? Which is an exact mirror of the scene in this case (and is often the case).
There is no way to ignore the mapping in NzbDrone, nor in this case would it be advised (if it were possible), for that matter, I don’t see why you would ever want to do this, if I’m missing something, please let me know.
How do we get XEM to update Pawn stars? Its a few episodes behind… The episodes are on TVDB and just need the translation to Scene it looks like, just needs the last four added.
Also american pickers looks to have a draft up that needs approved to make the changes for the seasons going to 2013 instead of season 2
Its a user submitted site, anyone can make the changes and request that they are made public, which usually happens within a day or two, sometimes faster; if you ask nicely in their IRC channel they can usually help you out very quickly.
There anyway to get around this so I can force the files to get renamed properly?
No. NzbDrone won’t even be able to see them properly without that mapping.
On a similar note, if I do a manual or automatic search of a single episode the XEM mapping is successfull but if I click “Search all episode in season 2013” it fails to grab anything.
From the log, it seems to search for S2013 (tvdb season) instead of S08 (scene season) :
FetchFeedService Usenet-Crawler offset [Pawn Stars : S2013]. Found 0
Right, I saw that before but forgot to add it to Trello its on there now: https://trello.com/c/NcaGD722/338-full-season-search-for-xem-mapped-series
