Restrictions and Tags
Hoping this is easy and possible, if not, fine.
I was curious if there was a way to make my downloads pull only shows with 5.1 audio?
For Instance,
House.of.Cards.2013.S03E13.1080p.WEBRip.x264-2HDnzbs
House.of.Cards.2013.S03E13.1080p.NF.WEBRip.DD5.1.x264-NTbnzbs
Instead of downloading twice, more than likely manually, is there a way to easily say I want the 5.1 Audio version? This might be a request beyond “must contain” and tags and more in line with the video quality requirements we can fine tune.
I mean, if I can say download 1080p web-dl, why is there no option to say 1080p and 5.1 audio? it would only make sense. There are obviously shows that would not benefit from 5.1 so being able to turn it on and off for certain shows would be great.
Release RejectedExisting file meets cutoff: WEBDL-1080p Quality for existing file on disk is of equal or higher preference: WEBDL-1080p v1
Now it would be nice for it to be 1080 and 5.1 audio track
Sonarr doesn’t look at the audio channels so required words would be what you want, but its not going to upgrade if its the same quality (source + resolution).
Preferred words might offer some support for this, but it will depend on whether we compare which whats available at the time or always all upgrading (this is TBD).
I guess the other option is size. lets call a hour show 2-3GB (1080p) with 5.1 and under 2 without 5.1? maybe.
That would be a guessing game and could result in missing media.
