Required/Ignored words applying to everything not just shows tagged
I have a show that has both the main show and then a “Backstage” version that airs later. I had issues where the main show was downloading the behind the scenes version and so I added a restriction with the word and a tag which I then added to the main show. Recently I decided to start downloading the backstage version but Sonarr won’t pick it up and when I do a manual search It say’s it was rejected for containing a restricted word even though it doesn’t contain the tag.
Example:
Series:
Main Show | Tags: nobackstage
Main Show: Backstage | Tags: N/A
Restrictions:
Must Contain: N/A | Must Not Contain: Backstage | Tags: nobackstage
I also tried added a second restriction resulting in the following:
Series:
Main Show: Backstage | Tags: backstage
Restrictions:
Must Contain: Backstage | Must Not Contain: N/A | Tags: backstage
Sonarr Ver. 2.0.0.4645
Running in docker container on UnRaid
Am I misunderstanding how restrictions/tags work?
As mentioned on github we’ll need to see ((debug logs)).
