2.0.0.5252
5.18.0.225
OS:
Synology DSM
I’m trying to setup my NAS to act as a Plex server and run Sonarr/Radarr. I want to be able to use a remote sever to handle downloads, what I’ve done is install Docker and a docker image for Sonar Inside the Sonarr docker I’ve installed sshfs and used the following to connect to my seedbox " sshfs name@IP:files/downloads /home/downloads/ -p PORT -o nonempty". I tested by using ls on the /home/downloads dir and saw all the downloads on my remote server. The issue I’m running into is after mounting to /home/downloads I can’t select it as a path for adding new shows.
I’m wondering if anyone can help point me in the right direction in terms of getting a remote downloader working.
