Hi, would be great if sonarr on NAS Synology DSM 6.2 could use ftp or webdav drive (distant connection) on a distant server for the remote remapping purpose.
Whatever path Sonarr accesses needed to be mounted locally, unless there is an FTP or WebDAV to filesystem mapping that will not be possible.
Well there is, because I have mapped my Seedbox by FTP locally it is called “Remote Connexion”, I can browse it using File Station and have access to all my files on my distant Seedbox. But in Sonarr, I cant see this “FTP link” so I cant use it to do a remote remapping path, even if it s available in File Station. That’s why I asked for this feature.
You can access the remote connection through File Station, but it does not have a local path. It is “connected” and not “mounted.”
OK thanks for the clarification. So I have to find a way to mount it.
I don’t think it’s possible, but please reply if you figure it out.
