Remote Path Mapping for Transmission
Sonarr version (exact version): 2.0.0.4230
Mono version (if Sonarr is not running on Windows): 4.4.2
OS: OSX El Capitan
((Debug logs)): http://pastebin.com/gTCutxqx
I’ve just got a WD MyCloud and I’ve got transmission running on it, so I’ve changed my sonarr setup to use that. It sends the torrent to transmission correctly, but I can’t figure out the remote path mapping settings so it moves the completed files properly.
My download client is on 192.168.0.24 with port 9091, and I have the following settings at the moment for remote path mapping:
Host: 192.168.0.24
Remote Path: smb://wdmycloud/Public/Transmission/Downloads/
Local Path: /Volumes/Public/Transmission/Downloads/
Sonarr is pointed at /Volumes/Public/Shared Videos/TV Shows and has found all the files on there with no problems, and I’ve tried a few variations on the remote path with no luck. The error I keep getting is consistently Import failed, path does not exist or is not accessible by Sonarr: /root/Downloads/filename.file
Remote path is the path the download client reports for /root/Downloads/DCs.Legends.of.Tomorrow.S01E03.WEB-DL.x264-RARBG you’d enter /root/Downloads.
The local path is the path that Sonarr can use to access that same path (it needs to be mounted locally), if that’s /Volumes/Public/Transmission/Downloads/ use that.
That did it, thank you so much!
