3.0.3.834
Both machines are Windows 10. Sonarr is on 10 Pro, and deluge in on 10 Enterprise
I have been using Sonarr for a bit, but have been moving the files manually after they download. I would like to take the time to Automate things a bit more.
I have recently set up a computer to be used only to torrent, and have installed Deluge. I got deluge setup as a daemon, and access it and monitor from the Deluge installed on my Main computer.
On my main computer I have Sonarr running. At the moment, this computer stores most of my Media, the is also a 3rd computer set up as a NAS that I am playing around with that stores some of my Media.
I have my Download client setup correctly to where it will start the downloads for me, but I canât seem to wrap my head around how to set up the remote paths.
The Deluge machine saves the finished downloads to âC:\torrents\completedâ
THe IP address of the Deluge machine ia 192.168.1.25
I have that folder mapped locally to the Sonarr machine as the Z: (\192.168.1.25\Completed)
I guess my confussion is about what does it mean by local path, and Remote path.
If I had to guess
Local path would be the path Local to the machine Sonarr is install on. So â\192.168.1.25\Completedâ or maybe âZ:â
Remote path it where the file is on the remote computer âC:\Torrents\Completedâ when I set it up, I get that the Local path doesnât exist, or when I donât get that error, ,sonnar doesnât move the files.
Permissions on the folder for testing purposes are open to âEveryoneâ having Full control.
Sorry in advance if I left anything out. Let me know and I will correct.
