No ones fault outside of the group that decided to jump up a season.
Intervention, at season 14, but the group released it at season 15.
No big deal, just killed the automation.
Anyone else face a scenario like this?
That’s why we have thexem.de
Looks like someone already made a draft of the show, so if it’s approved it will be fixed in sonarr automatically once the series refresh task runs (every 12 hours). Or you can force a refresh of that particular series as well.
Thanks for your feedback, had a feeling or hoped that someone kept track of these things.
I am still seeing Intervention on season 14 even though release groups are naming it 15. From the previous responses it seemed this was an easy fix but im stuck on how to implement it.
Thanks!
Join #xem on freenode (IRC), they can help sort you out.
this has been added. season 6+ should fetch just fine now.
