RaspBerry Pi
Hello
Is there a ver of NzbDrone that will run on a RaspBarry Pi
system?
Thank You
Not having it done it, I would start with a raspian install and follow linux install instructions. My ND is running under ubuntu in a Proxmox VM. I would do it to say I have done it, but not sure you would be happy with its performance.
I have 4 RPi’s , 3 newer models that handle xbmc stuff and a 4th original 256 m that I use experimenting with.
Not anything that we have looked at, it may work, but there are a number of dependencies in our code that may not work. This is an issue on Trello that shows issues running Arch on a rpi: https://trello.com/c/az6khHb3/410-arch-linux-on-arm-rpi-doesn-t-start
