I installed Sonarr on my raspberry pi again yesterday given the SD card had gotten corrupted so had to replace… It’s installed and can get to the interface but after every 2 minutes it stops, and then I have to go and restart it so nothing is getting done…
Do I uninstall (how to do that?) and re-install? Or how to fix it?
I think you need to check the logs of the RaspberryPi why it is happening,
perhaps it’s overheating
That is not the case - all other services running…It’s only Sonarr having issues.
Also complete linux novice - how do I check the logs? Happy to follow instructions to the letter.
Please advise
