latest version of sonarr
so i got the test to work just fine with the
https://torrentapi.org
url
but i cannot search episodes. or download.
my log says this.
Rarbg Error: SendFailure (Error writing headers)
no results found on anything. Help?
url
my log says this.
There are lots of threads here on that error (SendFailure (Error writing headers))
Such as: Rarbg / Torrentapi.org SSL error
You need libcurl installed so Sonarr can fallback to it, IIRC it’s lib curl4.
i have those enabled but it seems to not work still…look at this video i recorded…am i doing it wrong? :\
Which version of libcurl do you have installed?
The linked thread is using a different operating system so the package name is very likely not the same.
Sonarr is looking for libcurl.so.4 (as long as it comes from a lib location it should be fine).
nothing seems to work, I test them and they succeed, I also added jacket to see if I can get my demonoid account to work and it succeeded too. But still wont let me manually search to download each episode…nonetheless update my series.
Are you getting a different error then?
Unless you setup SSL on Jackett then it would communicate over http and wouldn’t be the same error.
What to the ((debug logs)) show?
Refreshing series is completely separate and doesn’t go over SSL, what d the ((debug logs)) show for that?
ok this is interesting now, I completely removed the nzbd geek thing and just left the indexers for the torrent sites…i think…it works now… wont let me manually pick them but…they seem to be downloading now…soo yay!
