It has been working for a whole week until it this morning (without any change) it just gives me this error.
One post said switching the API URL from “https://torrentapi.org” to “http://torrentapi.org” worked but it didn’t for me.
Shouldn’t be DNS problem because it has worked before. I use 1.1.1.1 and 1.0.0.1 DNS and nslookup for torrentapi.org works just fine. I’m also able to ping the addresses that it returns to me.
Even “http://torrentapi.org” lands me on webpage.
“https://torrentapi.org/pubapi_v2.php?get_token=get_token” doesn’t though…
While I was writing this I tried adding the RARBG on Jackett so I can then add jackett on sonarr but apparently https://torrentapi.org isn’t responding to jackett either.
Can anyone confirm if https://torrentapi.org/ is up or down ?
After changing your DNS settings, did you clear any DNS caches? I had a similar issue, with the torrentapi.org domain resolving to a parking page. Changing my DNS to the cloudflare DNS resolves it to cloudflare, and the indexer is accessible again.
Strange. They might be having DNS issues - as soon as I switched to the cloudflare DNS, it started working for me (about 3 minutes before my post above).
So… A few hours has passed and when I went on trying to open https://torrentapi.org/pubapi_v2.php?get_token=get_token on a web page, a 403 Forbidden error comes up. This means it’s working I guess. I went on Sonarr and retried testing the indexer and it worked just fine.
I guess the problem was with them…
Also, I’ve noticed that event though search works, you can’t go to the release page from the manual search link - it gives you 403 error. But adding the release to the queue works. No idea why the link doesn’t work though . . .
