Radarr Version - 5.22.4.9896
OS - Windows Windows 10 Build 18363
Debug Log - (wasn’t sure which text I needed, so copied all of it)
Good morning everyone. I am trying to figure out what is going on with my Radaar path mapping. During a previous install, Sonaar was also giving me the same error. I have since uninstalled everything and have only Radaar installed for now as I troubleshoot. For now, I’m only focused on getting Radaar running properly
My setup is as follows:
rTorrent downloads either a movie or tv show and moves it to a folder, either Movies or TvShows, based on the label it receives.
I have (x2) SyncThings shares set - one for the Movies folder and one for the TvShows folder. These are both working properly - dropping a file in the the Seedbox TvShows folder syncs to my home pc TvShows folder, and same for the Movies folder
Path to Seedbox Movies folder (removed = my username)
/home/(removed)/downloads/rtorrent/completed/Movies
Path to Home PC Movies folder (this is where SyncThings moves files to on my home pc)
F:\Temp Downloads\Movies
Current Remote Path Mapping:
Host - (removed).palawan.usbx.me (removed = my username)
Remote Path - /home/(removed)/downloads/rtorrent/completed
Local Path - F:\Temp Downloads\Movies
No matter what text I enter into the “Host” path, I get the same error:
“[/home/(removed)/downloads/rtorrent/movie name”] is not a valid local path. You may need a Remote Path Mapping
The path showing in the error is NOT the same path I have listed in the Path Mapping. At one point, I went as far as typing gibberish into the Host field just to see what happened - the error still shows the same incorrect path as listed above.
Can anyone point me in the right direction?
