pedro1x
February 29, 2016, 11:13pm
1
Hi,
I am a new user of sonarr, and I found it download the same episode twice sometimes.
I think it might be related to the profile.
What I would like is to download an episode in SD quality, if it doesn’t find it, to look for 720, and if not to look for 1080.
How should I configure that?
Thank you for any help.
-Mehdi
If you haven’t read: https://github.com/Sonarr/Sonarr/wiki/Profiles please do, it covers profiles and some of the things you can do with them.
If you still have questions let us know.
great
March 1, 2016, 9:02am
3
had the almost same question, here my setup. you can get an idea
Drag SDTV above 720p.
Set 720p as the cutoff.
Done.
First search returns SDTV and 720p? sonarr will grab SDTV because it meets the cutoff quality, and it is higher in the list than 720p so more desirable.
First search returns only 720p? sonarr will grab it because it meets the cutoff quality.
First search returns only SDTV? sonarr will grab it because it exceeds the cutoff quality.
In all 3 cases, when something new is found on RSS or search when you already have a file, it will not be down…
Nice, thank you for your help.
That would work for me. I guess if I don’t find 720 and want to look for 1080 , I use the same principle.
system
Closed
May 1, 2016, 4:41am
5
