Sonarr version (exact version): 3.0.2.560
Mono version (if Sonarr is not running on Windows): 5.18.0.240
OS: Synology
When I do Manual Import => Interactive Import, the popup automatically detects an episode correctly:
However, if I choose ‘Quick Import’, nothing happens. I (perhaps wrongly) assumed that Quick Import would find all the episodes in the download folder that Sonarr can automatically match, and import them, without any interaction by the user. Am I misunderstanding?
Also, assuming that’s what it’s supposed to do, and that it can be made to work is there an API endpoint in Sonarr I can poke via a curl command in a script so that I can trigger a Quick Import periodically, to automatically import stuff from my get_iplayer server that automatically downloads some shows for me? I’d like to kindof replicate the auto-import a bit like the old Drone Factory used to do.
