Sonarr version 3.0.6.1342):
OS Windows 10:
I like the handling I have setup with Sonarr, which is a category of ‘tv-sonarr’ and then it changes to ‘tv-sonarrdone’ when it’s finished. Which is great. Works well.
I also run a Connect task that logs away what was added, so a later process can come along and augment the subtitles and metadata clean things etc. Currently not running inline in Sonarr, but just saves it’s info for running later.
but say I manually grab something - I use non-sonarr category for those. And then was hoping to just change it’s category to ‘tv-sonarr’ and it would be processed through the normal Sonarr channels.
but it seems that is handled differently since it’s moving the episode files instead of hardlink/copying them. This of course makes it hard for my post processing stuff to work, since it’s looking for the original content in tv-sonarrdone but the ‘move’ has pulled away the video files.
Any way to adjust that behaviour or that’s by design?
