I currently have sonarr installed but its not right and has frozen its program whilst telling me there is a problem.
My question is pretty easy. What happens if I remove and re-install Sonarr. This should clean up any problems and I should be able to update the new sonarr with all the movies and series that there are right now.
If I do re-install is there anything I might want to save from the existing sonarr? (excluding that bad data thing)
I would really appreciate any thoughts on this…
