Sonarr version (exact version): forked the latest develop branch (I’m building as a contributor)
OS: Debian GNU/Linux 12 (bookworm). I’m specifically using Github Codespaces.
I’m following the contributor build instructions on this wiki page (the “Command line” section) :
https://wiki.servarr.com/en/sonarr/contributing
I run the following commands:
dotnet clean src/Sonarr.sln -c Debug
dotnet msbuild -restore src/Sonarr.sln -p:Configuration=Debug -p:Platform=Posix -t:PublishAllRids
The commands run without errors. I am getting lost on the next step:
"Run the produced executable from /_output"
When I go into the _output directory, I see the following folders:
- net6.0
- net6.0-windows
- Sonarr.Update
- UI
I then entered the net6.0 folder, then the linux-x86 folder. Inside that folder, I see lots of .dll files. I am looking for a file named Sonarr.Console but I don’t see any such file. The only executable I see is called “ServiceInstall”. When I run that file, I get the following error:
Unable to find Sonarr.Console.exe in the current directory.
I would appreciate any help you can offer. I would really like to get Sonarr running on Github Codespaces. Thank you.
