Sonarr version (exact version): 2.0.0.5163 Mono version (if Sonarr is not running on Windows): 5.12.0.226 OS: QTS 4.3.4.0569 Debug logs:
[v2.0.0.5163] System.DllNotFoundException: libmediainfo.so.0
at (wrapper managed-to-native) NzbDrone.Core.MediaFiles.MediaInfo.MediaInfo.MediaInfo_New()
at NzbDrone.Core.MediaFiles.MediaInfo.MediaInfo..ctor () [0x00006] in <9b8bbe29888f49229914613e26af4aa5>:0
at NzbDrone.Core.MediaFiles.MediaInfo.VideoFileInfoReader.GetMediaInfo (System.String filename) [0x00021] in <9b8bbe29888f49229914613e26af4aa5>:0
I’m running Qsonarr on my QNAP TS-128A with most recent QTS 4.3.4.0569 and, in the System section, I’m getting a warning “MediaInfo Library could not be loaded libmediainfo.so.0” which doesn’t the auto post-processing run properly (or at all).
I tried googling for some solution, but didn’t find any help for this particular configuration
Hello Again,
Trying to resurrect the topic…
It appears that while Sonarr is supposed to automate the entire process of downloading and file management, I need to login now and then and perform manual import because sonarr is not able to determine if file is a sample or not (due to missing limediainfo)
I’d really appreciate some support!
Could you please elaborate a bit - what does the ‘packaging issue’ mean in this context?
Is it something wrong with qmono?
I tried to seek help on qnap forum but got none…
