QSonarr_2.0.0.4326 and QMono 4.6.1.3 issue
QSonarr_2.0.0.4326 -> http://www.positiv-it.fr/QNAP/APP/QSonarr_2.0.0.4326.qpkg.zip
QMono 4.6.1.3 -> http://www.positiv-it.fr/QNAP/APP/Qmono_4.6.1.3_x86.qpkg.zip
Downgraded to QMono 3.10.0.2
OS: QNAP TS-439 II+
((Debug logs)):
sonarr.txt
sonarr.debug.txt
sonarr.debug.0.txt
I experience the following issue. With the last version of Mono, Qsonarr stop responding. I have to stop and start the application. Sometimes it works during 5 minutes; sometimes during few hours.
The all web site is slow, the calendar is slow, adding a new series does not update the poster properly.
Do you think it is related to the QNAP QPKG or is it linked to the Mono version ? What mono version do you use to validate your build ?
I have downgraded Mono to 3.10.0.2 as the 3.1 version seems to be included in the linux version. It solved my issue. The all application is now responding faster and also I dont have any more issue with the poster’s series update.
I’m having a similar problem with my QNAP TS-251+. I would first see the following error message:
Unable to communicate with Transmission. Cannot access a disposed object. Object name: ‘System.Net.Sockets.NetworkStream’.
Then it would stop responding all together.
Sounds like the same issue as:
