Sonarr version: 2.0.0.5319
OS: Windows 10
Debug logs: https://pastebin.com/5pDqNzw1
Trace logs: https://pastebin.com/m987iSsZ
Description of issue: Sonarr updated to the 2.0.0.5319 version in the morning and ever since the update, its not deleting the torrents in qBittorrent as it used to. I didn’t change any settings. The files are being moved to my TV series folders as normal but the torrents aren’t being removed anymore. Even after they are reported as completed in qBittorrent. Check here https://i.imgur.com/2iC0RIO.png
I check the files which were moved, they play fine and there are no issues, Here are my settings, https://i.imgur.com/8CLUQ74.png which I haven’t changed since ages ago. I have attached the debug log file as a pastebin. Please let me know what I should do to fix this.
Here are the files I just tested it with https://i.imgur.com/oE8pNSB.png
