Sonarr version (exact version): 3.0.0.348
OS: W10
Description of issue: With the recent changes in the Qbit API, I was just wondering if this version of Sonar will be fixed. I switched to the V3 because of the profiling, but If Qbit won’t be supported I might aswell switch back.
Thank you!
That version is almost a year old, look at the changelog and update.
I know! But I always check the update tab and there is nothing new, and the downloadable version from the website is the same as the one I’m using so I just assumed there was no new version. Should I go back to the other version or how can I update the v3 version?
edit: nevermind me, I found it! thank you!
