Here is my log with tracelog enabled:
Component Message Time
NzbDroneErrorPipeline Invalid request Validation failed:
– Unable to send test message 08:33
ProwlService Unable to send test message: API Key: "myboringapikey"is invalid: API Key: “myboringapikey” is invalid 08:33
ProwlService Invalid API Key: “myboringapikey” 08:33
I can clearly read that it says my api key is invalid but the key isnt invalid, I use it for other programs/script and it always work if I just restart Sonarr.
Mono version:
mono version is 3.2 or better: 4.2.2
Sonarr version:
Latest 2.0.0.4326 - Sep 13 2016
OS: Synology DSM Latest.
Its not permitted to upload .txt logs to the forum so here it is in raw text, tried to remove my api key from below text.
16-10-4 08:47:55.7|Trace|Http|Res: 1494 [GET] /logfile/sonarr.trace.txt: 200.OK (143 ms)
16-10-4 08:48:09.6|Trace|Scheduler|Pending Tasks: 0
16-10-4 08:48:22.4|Debug|ProwlService|The request timed out
[v2.0.0.4326] System.Net.WebException: The request timed out
at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) [0x00065] in /home/bean/spksrc/native/mono/work-native/mono-4.2.2/mcs/class/System/System.Net/HttpWebRequest.cs:946
at System.Net.HttpWebRequest.GetResponse () [0x0000e] in /home/bean/spksrc/native/mono/work-native/mono-4.2.2/mcs/class/System/System.Net/HttpWebRequest.cs:958
at Prowlin.HttpInterface.GetResultDocument (System.Collections.Generic.Dictionary`2 parameters, System.String method, Prowlin.ResultBase resultBase) <0x41aea2b0 + 0x00047> in :0
at Prowlin.HttpInterface.SendVerification (IVerification verification) <0x41aea130 + 0x00067> in :0
at Prowlin.ProwlClient.SendVerification (IVerification verification) <0x41ae3040 + 0x00031> in :0
at NzbDrone.Core.Notifications.Prowl.ProwlService.Verify (System.String apiKey) [0x00023] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Prowl\ProwlService.cs:68
16-10-4 08:48:22.4|Warn|ProwlService|Invalid API Key: "myboringapikey"
16-10-4 08:48:22.4|Error|ProwlService|Unable to send test message: API Key: “myboringapikey” is invalid
[v2.0.0.4326] NzbDrone.Core.Notifications.Prowl.InvalidApiKeyException: API Key: “myboringapikey” is invalid
at NzbDrone.Core.Notifications.Prowl.ProwlService.Verify (System.String apiKey) [0x0008b] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Prowl\ProwlService.cs:80
at NzbDrone.Core.Notifications.Prowl.ProwlService.Test (NzbDrone.Core.Notifications.Prowl.ProwlSettings settings) [0x00000] in M:\BuildAgent\work\6c3239faf2b92630\src\NzbDrone.Core\Notifications\Prowl\ProwlService.cs:88
16-10-4 08:48:22.4|Trace|NzbDroneErrorPipeline|Handling Exception
16-10-4 08:48:22.4|Warn|NzbDroneErrorPipeline|Invalid request Validation failed:
16-10-4 08:48:22.4|Trace|Http|Res: 1482 [POST] /api/notification/test: 400.BadRequest (100167 ms)
16-10-4 08:48:22.4|Debug|Api|[POST] /api/notification/test: 400.BadRequest (100167 ms)
16-10-4 08:48:39.6|Trace|Scheduler|Pending Tasks: 1
16-10-4 08:48:39.6|Trace|CommandQueueManager|Publishing MessagingCleanup
16-10-4 08:48:39.6|Trace|CommandQueueManager|Checking if command is queued or started: MessagingCleanup
16-10-4 08:48:39.6|Trace|CommandQueueManager|Inserting new command: MessagingCleanup
16-10-4 08:48:39.7|Trace|CommandExecutor|MessagingCleanupCommand -> CleanupCommandMessagingService
16-10-4 08:48:39.7|Trace|CommandQueueManager|Marking command as started: MessagingCleanup
16-10-4 08:48:39.8|Trace|CommandQueueManager|Cleaning up old commands
16-10-4 08:48:39.8|Trace|CommandQueueManager|Updating command status
16-10-4 08:48:39.9|Trace|EventAggregator|Publishing CommandExecutedEvent
16-10-4 08:48:39.9|Trace|EventAggregator|CommandExecutedEvent -> TaskManager
16-10-4 08:48:39.9|Trace|TaskManager|Updating last run time for: NzbDrone.Core.Messaging.Commands.MessagingCleanupCommand
16-10-4 08:48:39.9|Trace|EventAggregator|CommandExecutedEvent <- TaskManager
16-10-4 08:48:39.9|Trace|EventAggregator|CommandExecutedEvent -> TaskModule
16-10-4 08:48:39.9|Trace|EventAggregator|CommandExecutedEvent <- TaskModule
16-10-4 08:48:39.9|Trace|CommandExecutor|MessagingCleanupCommand <- CleanupCommandMessagingService [00:00:00.0988520]
16-10-4 08:48:46.9|Trace|Http|Req: 1495 [GET] /api/health
16-10-4 08:48:46.9|Trace|Http|Req: 1496 [GET] /api/diskspace
16-10-4 08:48:47.0|Trace|Http|Res: 1495 [GET] /api/health: 200.OK (17 ms)
16-10-4 08:48:47.0|Debug|Api|[GET] /api/health: 200.OK (17 ms)
16-10-4 08:48:47.0|Trace|Http|Req: 1497 [GET] /api/health
16-10-4 08:48:47.0|Trace|Http|Res: 1497 [GET] /api/health: 200.OK (10 ms)
16-10-4 08:48:47.0|Debug|Api|[GET] /api/health: 200.OK (10 ms)
16-10-4 08:48:47.3|Trace|Http|Res: 1496 [GET] /api/diskspace: 200.OK (319 ms)
16-10-4 08:48:47.3|Debug|Api|[GET] /api/diskspace: 200.OK (319 ms)
16-10-4 08:48:47.3|Trace|Http|Req: 1498 [GET] /api/diskspace
16-10-4 08:48:47.6|Trace|Http|Res: 1498 [GET] /api/diskspace: 200.OK (260 ms)
16-10-4 08:48:47.6|Debug|Api|[GET] /api/diskspace: 200.OK (260 ms)
16-10-4 08:48:50.2|Trace|Http|Req: 1499 [POST] /api/system/restart
16-10-4 08:48:50.2|Info|LifecycleService|Restart requested.
16-10-4 08:48:50.2|Trace|EventAggregator|Publishing ApplicationShutdownRequested
16-10-4 08:48:50.3|Trace|EventAggregator|ApplicationShutdownRequested -> NzbDroneServiceFactory
16-10-4 08:48:56.4|Debug|ProcessProvider|Found 0 processes with the name: NzbDrone.Console
16-10-4 08:48:56.7|Debug|ProcessProvider|Found 1 processes with the name: NzbDrone
16-10-4 08:48:56.7|Debug|ProcessProvider| - [14426] NzbDrone
16-10-4 08:48:57.3|Info|MigrationLogger|*** Migrating data source=/usr/local/nzbdrone/var/.config/NzbDrone/nzbdrone.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
16-10-4 08:48:57.9|Debug|MigrationLogger|Took: 00:00:00.6648492
16-10-4 08:48:57.9|Info|MigrationLogger|*** Migrating data source=/usr/local/nzbdrone/var/.config/NzbDrone/logs.db;cache size=-10485760;datetimekind=Utc;journal mode=Wal;pooling=True;version=3 ***
16-10-4 08:48:58.0|Debug|MigrationLogger|Took: 00:00:00.0444068
16-10-4 08:48:58.0|Info|Router|Application mode: Interactive
16-10-4 08:48:58.0|Debug|Router|Console selected
16-10-4 08:48:58.1|Info|OwinHostController|Listening on the following URLs:
16-10-4 08:48:58.1|Info|OwinHostController| http://*:8989/
