As someone who just went through the painful process of syncing TRaSH Guides’ Quality Definitions, Custom Formats and Quality Profiles via Recyclarr with Sonarr, I’m felt the need on proposing for functionality built directly into the app.
The Problem
Configuring Sonarr (and also Radarr) with optimal Quality Definitions, Custom Formats, Quality Profiles and Media Naming, currently requires users to rely on TRaSH Guides and third-party tools like Recyclarr or a significant amount of hard manual labour. While TRaSH Guides provide detailed and invaluable resources, they can feel overwhelming for new users.
Advanced tools like Recyclarr add complexity, as they require familiarity with YAML configuration and CLI setups. This technical and fragmented approach creates a steep learning curve, which can frustrate users, diminish the overall experience, or even discourage them from using these tools altogether.
Proposed Solution
Integrate TRaSH Guides’ recommended settings and profiles directly into Sonarr. This would include:
- Streamlined Setup: A GUI-based interface to select and apply Quality Definitions, Custom Formats, and Quality Profiles based on TRaSH Guides’ recommended settings without requiring on external tools.
- Toggle Options: Checkboxes to enable/disable specific features like size limits, codec preferences, or any additional settings directly within the app.
- Automatic Updates: A built-in option to automatically sync with TRaSH Guides’ latest recommendations, ensuring users always have up-to-date configurations.
- Advanced Customisation: Retain flexibility for advanced users by allowing manual tweaks and granular adjustments within the GUI or even keep on using tools like Recyclarr.
Benefits
- More Users Using Quality Profiles: Simplifies the process, encouraging wider adoption of optimised configurations.
- Simplified Configuration: Makes Sonarr more accessible for both new and experienced users.
- Eliminates Reliance on External Tools: No need for Recyclarr or manual syncing.
- Consistency: Keeps settings up-to-date with minimal effort.
- Enhanced User Experience: Lowers the barrier to entry and ensures a smoother workflow. By implementing this integration, Sonarr can significantly improve usability and provide a more intuitive experience for their users.
