Sonarr version (exact version): 3.0.8.1507-ls151
OS: Raspbian
Docker Compose:
version: "2.1"
services:
sonarr:
image: ghcr.io/linuxserver/sonarr:3.0.8.1507-ls151
container_name: sonarr
environment:
- PUID=1000 #Change to your PUID
- PGID=100 #Change to your PGID
- TZ=America/New_York
volumes:
- /srv/dev-disk-by-uuid-9fb8b015-f3e5-49e2-b15c-5f2f51dfc5b7/Torrents/appdata/Sonarr/config:/config
- /srv/dev-disk-by-uuid-9fb8b015-f3e5-49e2-b15c-5f2f51dfc5b7/Torrents/TV Shows:/tv
ports:
- 8989:8989
restart: unless-stopped
Native stacktrace:
(No frames)
Telemetry Dumper:
Pkilling 0x3060331568x from 0x3069630912x
Mono process hang detected, sending kill signal to pid 1401
clock_gettime(CLOCK_MONOTONIC*) failed; errno is 1
Native Crash Reporting
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Native stacktrace:
(No frames)
Telemetry Dumper:
Pkilling 0x3060315184x from 0x3069614528x
Entering thread summarizer pause from 0x3069614528x
Mono process hang detected, sending kill signal to pid 1407
Native stacktrace:
(No frames)
Telemetry Dumper:
Pkilling 0x3060659248x from 0x3069950400x
Mono process hang detected, sending kill signal to pid 1413
Native stacktrace:
(No frames)
Telemetry Dumper:
Pkilling 0x3060069424x from 0x3069368768x
Mono process hang detected, sending kill signal to pid 1419
Native stacktrace:
(No frames)
Telemetry Dumper:
Pkilling 0x3060675632x from 0x3069974976x
Entering thread summarizer pause from 0x3069974976x
mono_os_sem_timedwait: gettimeofday failed with "Operation not permitted" (1)Finished thread summarizer pause from 0x3069974976x.
Failed to create breadcrumb file (null)/crash_hash_0xd0ceba12f
Mono process hang detected, sending kill signal to pid 1425
I can’t get Sonarr to work after setting it up on Docker with Portainer. I have the 32 bit version of Raspian running on RPi4, so I made sure to use the older image.
