Problem with some torrents
Hello.
On one of my trackers, I get this error when trying to download the torrent: http://pastebin.com/raw.php?i=WxHXj1H7
I digged in it a bit, and found that this tracker has a “comment” property as the last property (so it’s not alphabetically ordered). But my torrent program can open the files just fine, so it’s only Sonarr causing a problem with this. Any chance you could ignore if the keys are in alphabetical order or not?
https://wiki.theory.org/BitTorrentSpecification#Dictionaries
Why should we adjust something (in a thirdparty lib we use) because a file doesn’t follow the standard?
Changing this behavior isn’t as simple as changing a boolean flag somewhere.
