Sonarr version (exact version): 2.0.0.4753
OS: Windows Server 2016
Hi,
I’ve noticed a problem with Sonarr being unable to connect to qBittorrent on the same machine.
I’m getting a health error that says:
Unable to retrieve queue and history items from qBit-local: JSON integer 18446744073709550000 is too large or small for an Int64. Path ‘[3].eta’, line 1, position 2647.
With following exception:
Newtonsoft.Json.JsonReaderException: JSON integer 18446744073709550000 is too large or small for an Int64. Path ‘[3].eta’, line 1, position 2647.
at Newtonsoft.Json.JsonTextReader.ParseNumber(ReadType readType)
at Newtonsoft.Json.JsonTextReader.ParseValue()
at Newtonsoft.Json.JsonTextReader.Read()
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.ReadForType(JsonReader reader, JsonContract contract, Boolean hasConverter)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at NzbDrone.Common.Serializer.Json.Deserialize[T](String json) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Common\Serializer\Json.cs:line 37
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.ProcessRequest[TResult](HttpRequestBuilder requestBuilder, QBittorrentSettings settings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 184
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrentProxy.GetTorrents(QBittorrentSettings settings) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrentProxy.cs:line 64
at NzbDrone.Core.Download.Clients.QBittorrent.QBittorrent.GetItems() in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\Clients\QBittorrent\QBittorrent.cs:line 98
at NzbDrone.Core.Download.TrackedDownloads.DownloadMonitoringService.ProcessClientDownloads(IDownloadClient downloadClient) in M:\BuildAgent\work\b69c1fe19bfc2c38\src\NzbDrone.Core\Download\TrackedDownloads\DownloadMonitoringService.cs:line 82
What can I do to fix it?
Thanks in advance.
